Let’s say the radio module inside one of my receivers stops working or gets damaged. Is it safe to replace the radio module with one taken from another receiver that was already used in a different sensor or even order a new one? are radio modules interchangeable, or are they somehow paired / matched to a specific transmitter–receiver or sensor configuration (DigiMesh settings, keys, network parameters, etc.)? My main concern is data consistency downstream when sensor information is sent to AWS for our monitoring dashboards, can any downstream issue (AWS / Grafana) be fully solved by remapping the new sensor ID? Thank you!!!
Most sensor modules can be interchanged ( as long as sensors are gne2)
Gateway and modem radio modules can’t be used with sensors without setting them up for sensors.
thanks!! that answers my question
