I want to use this Endnode to read vibrations from a sensor that provides a 0-20mA output. Can the Endnode read this, or is it limited to 4-20mA?
Thank you
Industrial humidity sensor 4-20ma Current Loop 4-Channel Input endNode
Thank you
it can read 0-20mA. end node devices works like this , user sends a commands to read a channel and it responds with the value
Excellent
Thank you for your prompt reply Bhaskar !
I am looking to use this similar device to read 0-20mA.
Is there any additional configuration I need to account for or do I plug the same wires in as I would for a 4-20mA 2-wire configuration?
