I believe I found a bug in the logout.cgi file used by the gen 3 Ethernet module. I think after logging out it tries to return to the homepage (the ip address with no forward slash), but it is interpretting the IP address as a signed number when it shouldn’t. The end result is that logout.cgi sometimes tries to redirect you to a negative IP address.
For an example IP of 192.168.6.100, logout.cgi tries to redirect to “-64.-88.6.100”.
I wanted to follow up on this bug report and see if there have been any patches released. I am almost done building my test fixture and wanted to see if I could fix this issue before the product is released.
Awesome, you will need to download the latest NCD Config Tool or update your html file (currently the only html file supported is the 8-channel html file) in order to see this configuration option.
Nevermind, my last comment only applies to the ability to disable the automatic logout via the web portal that was also added. The logout bug should be fixed just with the firmware update.
