Is the data I showed you correct? Should I change the delay value on the other side?
what do you mean by other side
Are the battery settings on the data screen correct?
you need to select auto confg and set the delay value to 0 and ODR to 800
I am curious as to why there is no battery consumption when ODR is set to 800Hz. I am curious as to why there is a difference in battery consumption when ODR is set to 100Hz.
i want to see how battery behaves when default settings are set.
