I received the:
Relay Controller 1-Channel General Purpose SPDT + 8 Channel ADC ProXR Lite - 5 Amp SPDT, and the
WiFi Communications Module with Bluetooth USB MQTT
I have downloaded and installed the Basestation software.
The Relay board is connected to a 12VDC supply
The Relay board is also connected via USB to a Windows 10 computer. The USB device is recognized at a “Silicon Labs CP210x USB to UART Bridge(COM11)”
At startup, the comm board displays a blue and a red LED, that quickly changes to green and red, then to just the red LED flashing twice in quick succession.
When I run Basestation and select COM11 and 115200 baudrate and click OK, Basestation tries to connect and displays a message (The controller did not respond at the baud rate you selected), tries a bunch of other rates, fails and exits.
It does not advertise for Bluetooth pairing, and does not show up as a WiFi access point.
Any suggestions as to how I can get Basestation to talk to the relay module?
Any suggestions at all from the company on this one?
I have spent a fair amount of time trying to get you product to be recognized by my Windows machine, to no avail. I posted a fairly detail description of the problem above, and heard nothing at all.
Ultimately, there was incorrect firmware in the radio module. The company supplied a radio module with the correct firmware, and I was able to
a) push the ‘c’ button to take the radio module to configuration mode,
b) connected to the radio module via WiFi (NCD_NexGen/NCDBeast)
c) went to the associated URL at http://172.217.28.1/ (Caution: This is google’s URL. Make sure you subnetting is setup correctly
d) On the web page, turned on bluetooth.
After that, the steps I used to configure an embedded Debian system to talk to the relay board are as follows:
The following commands enabled communication with the NCD.io relay board from a Debian Linux system (Debian 9.12 stretch)
Note: For whatever reason, the rfcomm executable refused to run with rfcomm built into the kernel (It would generate Protocol Not Supported errors). Rebuilding the kernel with rfcomm built as a module resolved this issue. (?)
Note2: Not absolutely sure we need to pair using bluetoothctl first, but that is what I did, and it ended up working. The bluetoothctl dialog below is paraphrased. YMMV.
use bluetoothctl to pair with the device
$ bluetoothctl
power on
scan on
wait for device to appear
Discovery started
[CHG] Controller 00:19:86:00:3D:50 Discovering: yes
[CHG] Device 30:AE:A4:D8:88:4A NexGen
scan off
trust 30:AE:A4:D8:88:4A
Changing 30:AE:A4:D8:88:4A trust succeeded
pair 30:AE:A4:D8:88:4A
message indicating successful pairing
devices
The above is persistent across reboots, so only needs to be done once. It appears
