colson
April 18, 2019, 3:23pm
#1
I have a WI-FI_EXT_ANTENNA module on a XB2CMAC3XXXA_OPCTL16AL-10-AMP board.
I also have a ZUSB_SIDE which I am sing to commuincate with the board.
Base Station is mostly working except when I go to configure the WiFi. A green bar starts and goes to about 10% and then just hangs.
I’ve tried this on 2 different laptops and it does the same thing.
Am I doing something wrong?
jacob
April 18, 2019, 4:12pm
#2
What are the LEDs on the WiFi module doing when you connect the USB to the USB configuration adapter?
Did you use the instructions at: https://ncd.io/wifi-module-quick-start-guide/ under “Setup and Instructions”?
colson
April 18, 2019, 5:17pm
#3
I do not have a USB configuration adapter.
I guess the question is, can the WiFi module be configured when plugged onto the XB2CMAC3XXXA_OPCTL16AL-10-AMP board or does the WiFi module have to be configured with a ZIGMO adapter?
jacob
April 18, 2019, 5:54pm
#4
It must be configured through a ZigMo or equivalent.
