Base Station modification, publication and instllation
I have ProXR and R810Pro relay controllers that I use in my Astronomical Observatory. I have modified Base Station from the source code to address all of the relay boards and to connect by WiFi or serial. I am using Visual Studio 2019 and my code works great to connect and run the controllers. I want to publish the code and install it on my observatory computer as an application.
I clean and build the code, then publish it. However, it will not install. I am not an expert coder, so I thought I would seek some guidance. The error is listed below followed by the installation log. It appears to have something to do with the “downloaded assembly NCD Configuration Utility.exe.”
Any help on this would be greatly appreciated
ERROR DETAILS
Following errors were detected during this operation.
* [6/7/2023 8:15:24 AM] System.Deployment.Application.InvalidDeploymentException (RefDefValidation)
- Reference in the manifest does not match the identity of the downloaded assembly NCD Configuration Utility.exe.
- Source: System.Deployment
PLATFORM VERSION INFO
Windows : 10.0.22621.0 (Win32NT)
Common Language Runtime : 4.0.30319.42000
System.Deployment.dll : 4.8.9032.0 built by: NET481REL1
clr.dll : 4.8.9139.0 built by: NET481REL1LAST_B
dfdll.dll : 4.8.9032.0 built by: NET481REL1
dfshim.dll : 10.0.22621.30000 (WinBuild.160101.0800)
SOURCES
Deployment url : file:///J:/Temp/Observatory%20Control%204.0.application
Application url : file:///J:/Temp/Application%20Files/Observatory%20Control%204.0_1_0_0_7/Observatory%20Control%204.0.exe.manifest
IDENTITIES
Deployment Identity : Observatory Control 4.0.application, Version=1.0.0.7, Culture=neutral, PublicKeyToken=0000000000000000, processorArchitecture=x86
Application Identity : Observatory Control 4.0.exe, Version=1.0.0.7, Culture=neutral, PublicKeyToken=0000000000000000, processorArchitecture=x86, type=win32
APPLICATION SUMMARY
* Installable application.
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of J:\Temp\Observatory Control 4.0.application resulted in exception. Following failure messages were detected:
+ Reference in the manifest does not match the identity of the downloaded assembly NCD Configuration Utility.exe.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
* The manifest for this application does not have a signature. Signature validation will be ignored.
OPERATION PROGRESS STATUS
* [6/7/2023 8:15:18 AM] : Activation of J:\Temp\Observatory Control 4.0.application has started.
* [6/7/2023 8:15:18 AM] : Processing of deployment manifest has successfully completed.
* [6/7/2023 8:15:18 AM] : Installation of the application has started.
* [6/7/2023 8:15:18 AM] : Processing of application manifest has successfully completed.
* [6/7/2023 8:15:22 AM] : Found compatible runtime version 4.0.30319.
* [6/7/2023 8:15:22 AM] : Request of trust and detection of platform is complete.
ERROR DETAILS
- Stack trace:
at System.Deployment.Application.DownloadManager.ProcessDownloadedFile(Object sender, DownloadEventArgs e)
at System.Deployment.Application.FileDownloader.DownloadModifiedEventHandler.Invoke(Object sender, DownloadEventArgs e)
at System.Deployment.Application.FileDownloader.OnModified()
at System.Deployment.Application.SystemNetDownloader.DownloadSingleFile(DownloadQueueItem next)
at System.Deployment.Application.SystemNetDownloader.DownloadAllFiles()
at System.Deployment.Application.FileDownloader.Download(SubscriptionState subState, X509Certificate2 clientCertificate)
at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
— End of stack trace from previous location where exception was thrown —
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
You might try going to the “Project” pull down menu and look at the last option, which will probably say “Base Properties”. It will have a small wrench icon and is the last item in the pull-down menu list. Check to make sure all the namespaces are correct. Next, click the “Publish” button in the list on the left side and make sure everything is set with the correct names and paths. Hopefully, this will help get you going.
