I am currently using a Fusion 8-Channel Relay controller with a Gen 3 Ethernet module.
I’ve been trying to get to the point to test the relays within the Base station software. I have successfully configured a static IP on the ethernet module (192.168.1.88). Also note I have the ethernet directly plugged into my computer.
This IP address is now discoverable on the “Discovered Network Devices” section. However when I choose this and press OK, after a few moments a window pops up and says “Device Identification Failed”
What am I missing, how can I be able to configure the ethernet module but then it still shows up as not being able to communicate with the board? Any direction will be appreciated.
-Chase
