I have the Enterprise Gateway Lite and would like to send the data to Azure IoT Hub. I understand that there is a Azure Node that can be imported into Node Red.
Do you have any guides that would help me to do this?
Also, your documentation suggests there is an example flow for the standalone vibration sensor, but this does not appear to be installed on the gateway out of the box. Can you share this too?
Charles
