Hello all, we are in need of a relay controller board with latching small signal relays, say around 50V @ 0.5A contacts. The relays will need to retain their status when power is removed from the board. Do you have any relay controller boards with such relays? We are early in our project and could accommodate several different input signaling requirements, so please let us know what boards you have available. Thanks for your help.
Sorry, no latching relays at this time. While we have considered the use of these relays, they are significantly more expensive, more complex to drive, and we don’t get enough requests to justify the investment. It’s typically more cost effective to make sure power is not lost by providing a backup power supply. I appreciate the inquiry though…
Please let us know if you have more questions.
Hello Ryan, thank you very much for the response and information.
Mark
No problem, please let me know if you need anything else.
