Greetings, I would like to build an LED display that measures the current draw of a pump. The pump pulls a max of 250 amps, so I thought I would use the XB2CMAC1XXXA_OPCTL38AL-600-amp current monitor. Can I then interface that to/through an Arduino board to an LED display?
Thank you in advance, this is my first Arduino-type project.
Outstanding! Thank you so much! Are those the only 2 boards I need, or do I need something that interfaces between the two (logically, not necessarily physically). Sensor-what?-display
You will need the Arduino to read the sensor, but the display chains to the sensor I2C output port. The display comes with the cable, so all you really need is Arduino code for the display and the sensor to get it all working. The display is powered from the I2C bus of the sensor, so you don’t even need any power to run it. Hope this helps.
