as per subject the nodes of “ncd-io/node-red-enterprise-sensors” are not deployed anymore.
A more detailed description of the error is:
[@ncd-io/node-red-enterprise-sensors/ncd-wireless] Error: Error relocating /config/node_modules/@serialport/bindings/build/Release/bindings.node: _ZN2v89Exception9TypeErrorENS_5LocalINS_6StringEEE: symbol not found
[ncd-red-comm/ncd-comm] Error: Error relocating /config/node_modules/@serialport/bindings/build/Release/bindings.node: _ZN2v89Exception9TypeErrorENS_5LocalINS_6StringEEE: symbol not found
I’m not sure I’ve seen this after updating just node-red, but after changing nodejs I’ve seen similar issues. Can you try these commands from a new command line:
cd .node-red
npm rebuild
npm install
npm rebuild
if that doesn’t work I would try these commands from a new command line:
cd .node-red
npm uninstall @ncd-io/node-red-enterprise-sensors
npm install @ncd-io/node-red-enterprise-sensors
The serial port library we use requires compilation so if the nodejs version changes a rebuild is required.
Jacob,
sorry for my late reply but I was trying a lot of times and with different approaches what you suggested me but with no success… any other clue?
If the uninstall and reinstall didn’t work then it may be an issue with the the underlying nodejs setup i.e. permissions on necessary file structures, npm configs, or Python and build tools.
What version of nodejs and npm are you running? What OS is this installed on?
I don’t have any experience with Home Assistant. I believe its built on Linux so it should be compatible with the Serial Port library we use.
I didn’t see where you listed an npm version. You can try updating this and seeing if this resolves the issue for the uninstall/reinstall or the rebuild commands. The command is usually:
npm install -g npm@latest
As for the rest Node-Red currently recommends node.js version 20 for node-red version 4.x. You can try downgrading and trying to reinstall the module again.
You can check to see if npm is referencing an older version of nodejs erroneously by running the command:
npm version
then looking for the node property on the response. i.e.
npm version
npm: ‘10.8.2’,
node: ‘20.18.1’,
acorn: ‘8.12.1’,
ada: ‘2.9.0’,
ares: ‘1.33.1’,
base64: ‘0.5.2’,
brotli: ‘1.1.0’,
cjs_module_lexer: ‘1.4.1’,
cldr: ‘45.0’,
icu: ‘75.1’,
llhttp: ‘8.1.2’,
modules: ‘115’,
napi: ‘9’,
nghttp2: ‘1.61.0’,
nghttp3: ‘0.7.0’,
ngtcp2: ‘1.1.0’,
openssl: ‘3.0.15+quic’,
simdutf: ‘5.5.0’,
tz: ‘2024b’,
undici: ‘6.20.0’,
unicode: ‘15.1’,
uv: ‘1.46.0’,
uvwasi: ‘0.0.21’,
v8: ‘11.3.244.8-node.23’,
zlib: ‘1.3.0.1-motley-71660e1’
is what mine responds with so I know i’m running node version 20.18.1 and v8 engine 11.3.244.8-node.23
