I am testing a ADS1115 and I have an issue with the data. I am using a 4-20mA loop simulator to test the output. The board is set as follows;
Default address, Gain 2 (2.048v), mode continuous, rate_128
If I set the loop simulator to 4mA the device returns 6415 (expected), and setting the sim to 20mA the device returns 31930 (also expected) if I set the sim at 12mA I get 19,160 (not expected). I have tested with more that one loop simulator.
I expect I am missing something basic but why is the data output not linear?
