Hello, I am new to programming NCD boards and I have a 12 relay I/O ethernet board. The manufacturer of the board is Denkovi. I am able to ping it with the default address and I can turn on and off the relays/outputs via the web browser. What I am trying to do now is to be able to write some code in vb.net to control the relays with the push of a button. I have downloaded the NCD component library plug in to my vb library, according to the sample code from this link https://ncd.io/ncd-component-library-quick-start-guide/
but when I went to run it, it didn’t fire the output. So now I am wondering if there is another command that I need to use in order to turn on and off my outputs. any help would be helpful, because I am completely stumped!
