I accidentally did a total factory reset on the gateway. I double held the reset button and it looks like it completely wiped the gateway back to robustel factory. Do you have any scripts that I can do to get it to NCD factory configuration?
Hi Dan,
Is this an Atrium Gateway with dashboarding or is this one of our Enterprise Gateways? They use the same hardware, but have different steps.
If it is an Enterprise Gateway can you load up the Robustel Dashboard and go to System > Profile and then click the Restore button next to Restore to Factory Default Configuration?
Hi it was an enterprise gateway, and it appears to have worked!
One thing I did notice is that it did not download the latest version of the NCD node pallette.
Thanks!
I have seen a factory reset corrupt the default libraries. You can try using this flow to resolve the issue: NCD-Edge-CR/configuration/flows/library-fixer.json at main · ncd-io/NCD-Edge-CR · GitHub.
Or if you have SSH access you can use this command:
cd /home/ncdio/.node-red && npm uninstall @ncd-io/node-red-enterprise-sensors && rm -rf /home/ncdio/.node-red/node_modules/@ncd-io && npm install @ncd-io/node-red-enterprise-sensors && npm uninstall node-red-dashboard && npm install node-red-dashboard
Let me know if you’re still encountering issues.
Thanks! i was able to get it up and running with that.
