Access Robustel WebUI on Atrium Gatreay
We purchased an Atrium Gateway for testing - so far, the new interface looks quite slick!
However, we would still like to access the conventional Robustel WebUI interface, since there are a lot of advanced networking features there (SSH access, etc) that are not available on the new interface.
Also the guide (Atrium Gateway - NCD.io) is still missing some screenshots (placeholder text), in case there is still a need to update that guide.
Thank you!
On that note, also accessing the Node-Red WebUI as well…
Hi @tulanowski sure, you can access the Robustel Web UI over port 8080 in order to setting up the network, SSH, etc. It was moved there so the Atrium Dashboard would be available at port 80.
To access the Robustel dashboard in your browser enter http://ncd-XXXX:8080 where XXXX is replaced with the last 4 digits of your gateway’s Mac address.
You can access to Node-RED interface by using : http://ncd-XXXX.local:1880
Thanks.
