900mhz Xbee products interference with Liftmaster?
I’m using a Liftmaster 850LM (310-390mhz) receiver for 500’ range remote access control (gate).
Do your XBee 900mhz PTP relay controllers communicate continuously, or only when the control/relay state is changed?
If they do communicate continuously, might they cause interference with the 850LM (intermittent commands) wireless communications if the antennas of the two remote systems are located 12-15 feet of each other?
For this application, I’m considering your two-channel XBee relay link product:
(https://store.ncd.io/product/wireless-contact-closure-transmitter-receiver-2-channel-spdt-relays-2-way-2/)
Thank you for your prompt reply and support.
Best Regards,
Bob
