Hi there,
We are looking to get the ncd sensors and gateway here in Malaysia, and for context, the allowed 900MHz frequency band here is limited to 919-923MHz. Based on the Digi XBee-PRO 900HP specifications, the module does cover a frequency band of 902-928MHz. Would it be possible to configure/limit the module’s frequency (through channel masking or other means?) within the allowed frequency band? Or is 2.4GHz the only available option for us? The difference in reachable range between the 900MHz and the 2.4GHz version could be an issue for our applications.
Thanks.
