Hi
802.15.4 Long Range Wireless Modem with USB Interface is in use. I want to factory-initialize this radio module to XCTU, but it’s not working well Is there a way?
Hi
Is X-CTU showing errors or it just won’t connect? Can you provide screen shots?
After updating firmware on the radio module
Gateway does not read sensor when node red is enabled
what profile did you load into the radio ?
Well done. Thank you for your answer.
incorrect profile was loaded ?
There was a problem with this part, but when I re-entered it, communication was established with the sensor.
