I would like to use the 1-Channel 4-20mA Current Loop Transmitter I2C Mini Module to transmit my sensor value to a Arduino MKR GSM 1400 board. The arduino board already have an I2C connector. Unfortunately, the board connector is 5 pins, the receiver 4 pins and the two connectors are differents.
Where can I found a female nodelynk connector to adapt an existing 5 pins arduino wire (by removing the additional pin) ?
Thanks for your answer but that’s not what I am looking for. I would like to have only the connector not the cable.
I have found this connector : is it compatible with the board ?
