I am trying to get my 1 channel ads1115, I2C shield, and arduino uno to read a miliamp signal that I have on a signal generator . This is the most basic configuration that I could devise.
Should I be using the default address on the ground? ads.getAddr_ADS1115(ADS1115_DEFAULT_ADDRESS);
How is gain determined in when using this with an arduino uno?
Should I be using single conversion or something else?
Using single-conversion my channels 1 through 4 display approx 250, 4200,4200, 4200 regardless of the milliamp that are generated. Is channel 1 the correct channel to use?
I will recommend this lib
and this test setup guide
Hi Bhaskar, I get the same results. The library provided is the one that I have been using. I updated my sketch to the exact code that you have provided.
12:31:54.011 β Digital Value of Analog Input at Channel 1: 245
12:31:54.083 β Current Loop Input at Channel 1: 0.154
12:31:55.049 β Getting Single-Ended Readings from AIN0β¦3
This value remains the same, regardless of the loop current value.
with no wires connected to the βinβ and βgroundβ on the ads1115 I get
13:08:25.007 β Digital Value of Analog Input at Channel 1: 306
13:08:25.081 β Current Loop Input at Channel 1: 0.192
13:08:26.042 β Getting Single-Ended Readings from AIN0β¦3
what current loop device are using to provide the signal
Are you referring to the signal generator when you say current loop device? When it was connected in the receiver; it was a 12-24v dc generator powered by a 20v battery.
yes the signal generator. it should be generating 4-20mA signal not voltage.
also this device provides the loop power, which means the signal generator should not provide power.
Yes it it is set to 4-20 mA. I have verified with 2 multi-meters to insure that it is giving the correct value in addition to the display on the signal generator.
Then how can I test the ads receiver? How I can generate a 4-20 mA signal?
