I recently purchased a 3 channel current sensor along with the USB modem that comes with it .
I am using the Alpha Sensor Viewer and it detects the sensor and I am receiving some type of data and am able to configure the sensor and everything. The issue here is , the sensor data always shows 0 ( the split core is wrapped around a live wire ) , the strange thing is when the entire split core setup is disconnected from the main sensor module it’s sending some gibberish values for all 3 current sensors .
This is the one that I have , which I am assuming to be 100A .
Hence 1.5 A would be its min current measured current ? The current that I am measuring right now is around 1.8A -3.6A .
I tried looping the wire multiple times as well , doesnt seem to help .
