I tried to read from 1-10 then 11-12 but couldn’t figure out how to do it.
What could I read to understand better this?
Also if helping me modify the code is possible, I will appreciate the time
This is the code that I am using that outputs ten channels then the error:
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# PECMAC125A address, 0x2A(42)
# Command for reading device identification data
# 0x6A(106), 0x02(2), 0x00(0),0x00(0), 0x00(0) 0x00(0), 0xFE(254)
# Header byte-2, command-2, byte 3, 4, 5 and 6 are reserved, checksum
command2 = [0x6A, 0x02, 0x00, 0x00, 0x00, 0x00, 0xFE]
bus.write_i2c_block_data(0x2A, 0x92, command2)
time.sleep(0.5)
# Read data back from 0x55(85), 3 bytes
# Type of Sensor, Maximum Current, No. of Channels
data = bus.read_i2c_block_data(0x2A, 0x55, 3)
# Convert the data
typeOfSensor = data[0]
maxCurrent = data[1]
noOfChannel = data[2]
# Output data to screen
print("Type of Sensor : %d" %typeOfSensor)
print("Maximum Current : %d A" %maxCurrent)
print("No. of Channels : %d" %noOfChannel)
# Command for reading current
# 0x6A(106), 0x01(1), 0x01(1),0x0C(12), 0x00(0), 0x00(0) 0x0A(10)
# Header byte-2, command-1, start channel-1, stop channel-12, byte 5 and 6 reserved, checksum
command1 = [0x6A, 0x01, 0x01, 0x0C, 0x00, 0x00, 0x0A]
bus.write_i2c_block_data(0x2A, 0x92, command1)
time.sleep(0.5)
# Read data back from 0x55(85), No. of Channels * 3 bytes
# current MSB1, current MSB, current LSB
data1 = bus.read_i2c_block_data(0x2A, 0x55, 0x20)
# Convert the data
for i in range(0, noOfChannel):
msb1 = data1[i * 3]
lsb = data1[2 + i * 3]
msb = data1[1 + i * 3]
# Convert the data to ampere
current = (msb1 * 65536 + msb * 256 + lsb) / 1000.0
print("Channel no : %d " %(i + 1))
print("Current Value : %.3f A" %current)
Sorry for the format, still learning
