0-10 VDC /Alerting on less than 1 V
We have a use case for the 0-10 VDC where we could like the sensor to send a value as soon as less 1 V is detected. We currently have the sensor set to report once every 2 minutes. Is this possible and if so, how?
no this device but you could use a push notification device with a device circuit to trigger a message as soon as voltage drops below 1V
Thank you Bhaskar…if I understand you correctly, for us to use the 0-10V sensor, we would need to decrease the uplink time to the shortest interval possible and catch the breach in threshold through the uplink reports.
Yes, that would be the only option if you are using 0-10V hardware. Also, make sure you are using it with external power, as batteries won’t last long.
Yes, that was my assumption. I am not sure of the use case as Greg is at a meeting with global reps so will try to find that out.
