I have an NCD wireless Vibration/Temperature sensor [PR52-33N] and a wireless ethernet modem [PR55-17B]. Alpha Station connects to the modem just fine, but when I switch on the sensor I get no sensor data showing up.
Is the sensor supposed to connect automatically to all nearby modems, or is there some setup/configuration that I’ve missed? When I switch on the sensor, am I supposed to see it show up automatically on the modem in Alpha Station?
I need to verify this device because we did have a mishap yesterday with bad batteries where the batteries started leaking immediately when someone put them in. We removed those batteries and replaced them with new ones, and I need to verify whether the device is still working or not. I have done the factory reset procedure.
I inherited these devices so I don’t know if anything was changed on the modem. In the Alpha software I clicked on the two buttons “Use default Pan ID” and “Use default encryption key” and then clicked “Write modem settings” button to see if that would reset it. I’m not sure if that is the proper procedure though.
None of the “lights” in the UI ever light up. This error message comes up if you hit enough buttons. But usually the UI just sits there doing nothing. There is no indication that the unit is alive except when I put the multimeter on those pins I can see voltage when the pwr switch is in the On position, but when the switch is in the Off position there is no voltage.
