Wireless Environmental sensor - Sleep interval settings response
I followed the manual ncd-io-wireless-sensor-raw-commands and set up the environmental sensor.
It was working fine, but to make sure the sleep interval is configured right, I wish to know exact meaning of parameters in data frame (Payload).
As per the document, under Set Sensor Node ID and Sleep Duration topic:
Here which byte says the success or failure?
7C 01 05 00 0E 00 00 FF 00 00 00 00 00 00 00 00 - I can understand, this is the payload. 7C is header. But can’t find the meaning for other bytes in the payload.
Now once this frame comes, it works successfully. But not sure how to identify failure. Please help me know these parameters.
Thanks in advance.
FF indicates that command was a success
Thank you. Is there any documentation or manual to know more about all the parameters?
i wil recommend checking out sensor product page (resources section).
