We recently ordered a Wi-Fi Micro Gateway for AWS and I need the mac address in order to connect to our wifi enterprise network but I don’t know how to find it.
Thanks.
Hi @jacques.secondi sure, I would recommend connecting the Micro Gateraw to a temporary network that allows device connections, ensuring that your PC is also connected to the same network.
One option is to access the DHCP client list on your router after your PC is connected, where you can find the MAC address.
Alternatively, once connected, you can open a command prompt in Windows and run the following command:
arp -a
This command displays the ARP table, which contains a list of IP addresses along with their corresponding MAC addresses. should show you the mac address of the Micro Gateway.
@TravisE_NCD_Technica I’m not sure if the MAC address is already available in the Micro Gateway interface following any firmware updates.
Please try this and feel free to let us know if you have any questions.
Thank you.
Eduardo M.
