What is the Shunt Resistor used in ADS1115 2-Channel 4-20mA current loop receiver
Im interested in getting this module which takes an input of a 0-20 mA transducer and converts it to a digital voltage signal. I see that it uses the INA196 current loop monitoring, but im curious to know what is the resistance of the shunt resistor used in that loop. I can’t find it anywhere in the specs or datasheets.
Thanks y’all
its 4.99 ohm …
