What is the Output Voltage of the 4-20mA Current Loop Receiver PR33-10?
For example the PT5443 sensor/transmitter would operate in the range of 8,5…36 DC.
In the wiring diagram the PR33-10 is shown without external power supply operating a 2 wire current loop sensor.
Luca
PR33-10 provides loop power supply
I understand that from the diagram, but which range of sensor voltage requirement is compatible?
PR33-10 has nothing to do with range. it will depend on your sensor. if your sensor can work at 16V then this device will work with it.
