I am using the python3.9 interpreter with the pyserial and ncd_industrial_relay api,
I am getting some very strange behavior with relay 2 and relay 10.
Using Linux Raspbian
Initialized with lines:
con = serial.Serial("/dev/ttyUSB0", baudrate = 115200, timeout = 1)
controller = Relay_Controller(con) #<- ncd api
When I turn on relay 2 I hear a click and the light corresponding to two turns on… and the light for relay 10 turns on.
I receive the response:
>>> controller.turn_on_relay_by_index(2)
[True, [170, 1, 85, 0]]
Then if I turn on relay 10 – I hear a click, and the light for relay two turns off.
controller.turn_on_relay_by_index(10)
Then if I turn off relay 10 – I hear no click, and the light for 10 does not turn off, but the light for 2 turns back on.
controller.turn_off_relay_by_index(10)
If I repeat this say – turn relay 10 on again – the light for 10 turns on, the light for two turns off, and there is no click.
None of the other relays behave in this manner, additionally if I turn relay 10 on while relay 2 is off everything behaves as expected., but when I turn relay 10 off while relay 2 is off, the light corresponding to relay 2 flashes.
Any ideas what is happening?
