Hi guys,
I was wondering if this board had any watchdog timer on it:
Thanks!
Gustavo.
FYI @Travis
It does not, but we are experts at watchdog supervisory timers, so we can make them for you if they are really needed.
Sounds good
What do you have
Looking for timer that times down and needs to be reset by electron.
If no reset then it drives an output to reset electron.
Pat
Hi Pat,
We have to design a watchdog CPU specific to your needs. This can be expensive for a singular application but it typically pays off for larger volumes (100 pieces or more). A new board would also need to be created to support the watchdog features. We can use a PIC12F1840 custom programmed for your timing requirements. It will add two components to the board. If you are interested, we need to get @Anil_Bhaskar involved in the conversation. FYI: Our watchdog CPUs also include a hardware watchdog
Can contact me about this?
Pat
We are currently trying the TPL5110 from Adafruit. What your recommendation sounds like about the same thing ? Yes?
I think we are just missing a piece of the puzzle
Your thoughts
Hi Pat,
I have not worked with a TPL5110, we typically build our own supervisors when needed. If you need a low-power battery solution, the TPL5110 may be a better choice. Our supervisors are for always on applications where battery life does not come into play. Hope this helps.
Just looking a watch dog
Not using batteries
Quote me or send me some info please
Pat
