Hi, I have the One Channel Vibration Sensor Plus (PR55-61E). Which gateway should I use to connect the sensor?
We recommend an edge computer.
You can also use any mode and connect to your computer and run node-red over there.
It all depends on where you want to view the data.
If you want to view on the cloud, use an edge computer and push data to cloud services like ubidots.
