@scott.warnick Did the careful resetting of both sensors resolve the difference in reported vibration values?
Also, here is an idea, the time interval matters (I think). If each rms_x/y/z is calculated based on the vibrations during the time interval between messages, each sensor will report different results unless, theoretically, reset and messaging at the exact same time.
still having issues with the values on the sensors not matching up.
makes some sense that the values wouldnt be exactly the same, but should be the same order of magnitude connected to the same piece of equipment. The equipment isnt changing that much, load is constant.
The X, Y and Z are off, which is concerning.
