So I have connected my 4-CHANNEL 16-BIT 0-10V ANALOG TO DIGITAL CONVERTER to my raspberry pi with the i2c shield and cable, verifying connections here. The problem is the code does not seem to be getting any readings from the ADC. I see the ADC on pi with i2cdetect at address 68, and I have a variable power supply hooked up to the ADC just to ensure proper voltage readings prior to using a sensor. I’m now suspecting the code I got here for the MCP3428. Here is the code:
indent preformatted text by 4 spaces
I2C 16-Bit 4-Channel Analog to Digital Converter I2C Mini Module
Firmware v1.0 - Python
Author - Yadwinder Singh
4-Channel ADC with 16-Bit Resolution
4 Differential Analog Inputs
Programmable x1-x8 Gain Amplifier
Upto 8 Devices per I2C Port
Up to 3.4MHz Communication Speed
0x68 I2C Start Address
Hardware Version - Rev A.
Platform - Raspberry Pi
#Setting Up smbus libraries
import smbus
import time
bus = smbus.SMBus(1)
#MCP3426, MCP3427 & MCP3428 addresses are controlled by address lines A0 and A1
# each address line can be low (GND), high (VCC) or floating (FLT)
MCP3428_DEFAULT_ADDRESS = 0x68
MCP3428_CONF_A0GND_A1GND = 0x68
MCP3428_CONF_A0GND_A1FLT = 0x69
MCP3428_CONF_A0GND_A1VCC = 0x6A
MCP3428_CONF_A0FLT_A1GND = 0x6B
MCP3428_CONF_A0VCC_A1GND = 0x6C
MCP3428_CONF_A0VCC_A1FLT = 0x6D
MCP3428_CONF_A0VCC_A1VCC = 0x6E
MCP3428_CONF_A0FLT_A1VCC = 0x6F
# /RDY bit definition
MCP3428_CONF_NO_EFFECT = 0x00
MCP3428_CONF_RDY = 0x80
# Conversion mode definitions
MCP3428_CONF_MODE_ONESHOT = 0x00
MCP3428_CONF_MODE_CONTINUOUS = 0x10
# Channel definitions
#MCP3425 have only the one channel
#MCP3426 & MCP3427 have two channels and treat 3 & 4 as repeats of 1 & 2 respectively
#MCP3428 have all four channels
MCP3428_CONF_CHANNEL_1 = 0x00
MCP3428_CHANNEL_2 = 0x20
MCP3428_CHANNEL_3 = 0x40
MCP3428_CHANNEL_4 = 0x60
# Sample size definitions - these also affect the sampling rate
# 12-bit has a max sample rate of 240sps
# 14-bit has a max sample rate of 60sps
# 16-bit has a max sample rate of 15sps
MCP3428_CONF_SIZE_12BIT = 0x00
MCP3428_CONF_SIZE_14BIT = 0x04
MCP3428_CONF_SIZE_16BIT = 0x08
MCP3428_CONF_SIZE_18BIT = 0x0C
# Programmable Gain definitions
MCP3428_CONF_GAIN_1X = 0x00
MCP3428_CONF_GAIN_2X = 0x01
MCP3428_CONF_GAIN_4X = 0x02
MCP3428_CONF_GAIN_8X = 0x03
#Default values for the sensor
ready = MCP3428_CONF_RDY
channel = MCP3428_CONF_CHANNEL_1
mode = MCP3428_CONF_MODE_CONTINUOUS
rate = MCP3428_CONF_SIZE_12BIT
gain = MCP3428_CONF_GAIN_1X
VRef = 2.048 # 2.048 Volts
# Power on and prepare for general usage.
def initialise():
# Default :Channel 1,Sample Rate 15SPS(16- bit),Gain x1 Selected
setRate(ready)
setChannel(channel)
setMode(mode)
setSample(rate)
setGain(gain)
# Set Ready Bit
#In read mode ,it indicates the output register has been updated with a new conversion.
#In one-shot Conversion mode,writing Initiates a new conversion.
def setRate(ready) :
bus.write_byte(MCP3428_DEFAULT_ADDRESS, ready)
#Set Channel Selection
#C1-C0: Channel Selection Bits
#00 = Select Channel 1 (Default)
#01 = Select Channel 2
#10 = Select Channel 3
#11 = Select Channel 4
def setChannel(channel) :
bus.write_byte(MCP3428_DEFAULT_ADDRESS,channel)
#Set Conversion Mode
#1= Continous Conversion Mode
#0 = One-shot Conversion Mode
def setMode(mode) :
bus.write_byte(MCP3428_DEFAULT_ADDRESS,mode)
#Set Sample rate selection bit
# 00 : 240 SPS-12 bits
# 01 : 60 SPS 14 bits
# 10 : 15 SPS 16 bits
def setSample(rate) :
bus.write_byte(MCP3428_DEFAULT_ADDRESS,rate)
#Set the PGA gain
# 00 : 1 V/V
# 01 : 2 V/V
# 10 : 4 V/V
# 11 : 8 V/V
def setGain(gain) :
bus.write_byte(MCP3428_DEFAULT_ADDRESS,gain)
#Get the measurement for the ADC values from the register
#using the General Calling method
def getadcread() :
data = bus.read_i2c_block_data(MCP3428_DEFAULT_ADDRESS,0x00,2)
value = ((data[0] << 8) | data[1])
if (value >= 32768):
value = 65536 - value
return value
# The output code is proportional to the voltage difference b/w two analog points
#Checking the conversion value
#Conversion of the raw data into
# Shows the output codes of input level using 16-bit conversion mode
def getconvert():
code = getadcread()
#setSample(rate)
N = 12 # resolution,number of bits
voltage = VRef*code*0.00034
#voltage = (2 * VRef* code)/ (2**N)
return voltage
#Initialising the Device.
initialise()
voltage = 0.00
while True:
time.sleep(0.5)
voltage = getconvert()
print (" MCP3428 Readings ")
print ("\nVoltage of the source is :",voltage,"volts\n")
print (" **********************************\n")
