I just received my PEVMAC2C ac voltage monitor. Using the github python code ‘voltage.py’ by bhaskar-anil429 I get the following output:
Type of Sensor : 5
Maximum Current : 240 A
No. of Channels : 2
Channel no : 1
volt Value : 119.876 A
Channel no : 2
volt Value : 120.684 A
Looks reasonable, running the script again (about 10 seconds later) I get :
Type of Sensor : 5
Maximum Current : 112 A
No. of Channels : 130
Channel no : 1
volt Value : 119.940 A
Channel no : 2
volt Value : 121.493 A
The second (third, forth, fifth, …) time the script is executed the Maximum Current is always 112 A and No. of Channels is always 130. (I understand that ‘A’ should really be ‘V’. ‘voltage.py’ appears to be a modification of the code for the current monitors that never got fully amended.)
I have the PECMAC2100A current sensor that uses very similar code and it has worked flawlessly. Any ideas what’s happening to the voltage monitor that I’m getting 130 channels?
