We have several deployed Type 84 sensors, https://store.ncd.io/product/smart-industrial-iot-wireless-vibration-temperature-sensor/
We equipped them with 868Mhz Xbees as they are deployed over in the UK.
We are seeing excessive battery drain on them that we cannot quite determine the reason for. While we cannot remotely check, I had suspicions that the ‘SM Sleep Mode’ might have been set to ‘Normal’ but upon checking the profile used to flash these xbees, they were set to ‘Async. Pin Sleep [1]’.
It is definitely a possibility that those that we did not flash, those that did just work, were set to Normal and are the ones that are draining the batteries.
Anything else I can check for why these sensors might be draining batteries faster than normal?
