Setting Deadband zero will introduce some noise when the machine is off. It will pick the vibration from the surrounding area.
There is no disadvantage to setting it to zero.
@leenve the general way to do this is to use the ncd-red-wireless-2 Node-Red library.
That Node-Red library gives you two objects, a ‘Wireless Gateway’ and a ‘Wireless Device’ node.
The Wireless Device node is the one you want for this.
Configure the Wireless Device Node with the Modem (Serial, Serial Device for Config) and then choose the sensor type.
If you only want to config a specific device in this manner, choose its mac address (if it has transmitted and been heard) or type it in. I think lowercase is necessary with colons.
Check the box for Auto Config, and OTF Config. The OTF Config is the key to doing what you want here.
Then scroll down and check the Set Dead Band
The sensors check for config on about the 4th minute of every hour if their Real Time Clock (RTC) is enabled. They then talk to the gateway, and get the new setting applied.
In my experience this works pretty will but I tell people it will take a few hours to get applied, and also depending on how many sensors, and what their Node_Ids are.
The Node_Ids are enough to fill a separate post, but are important not to have too much nodeId overlap because the timing of that OTF Config is 4th minute of hour + (nodeID * 5sec)
If you have too many sensors all on the same nodeID they might all respond/talk at the sametime and overwhelm your RF.
