I’m new to this and learning as I go.
I have a MIRCC8 Push Notification Board connected to ethernet and am trying to get it to talk to the N-Button Pro software running on a PC, but so far have not been successful beyond getting a gray widget to appear on the desktop.
Briefly, I have set up the board using the web interface for a static address of 192.168.1.51, TCP Server with Local Port of 2101, Remote Host of 192.168.1.50 (the computer running N-Button software), with a Remote Port of 5000. UART info is 115200 N81.
I have the N-Button software set up with a Push Notification device and network address of 192.168.1.51, TCP Port of 2101, UDP Port of 3333, and TCP Connection is checked. The widget is set up in Bank ID: 1 and Channel ID: 1
I understand the gray widget signifies the two devices are not talking to each other, so I’m at a loss of where to go from here.
