Our Temperature sensors are reporting 130C, this seems similar to the following forum post to which no resolution was posted, can you advise what can be done for this? Thanks.
This is the affected product:
Can you check the last photo that customer posted in the forum? Some of the early production run units of this product did not have the PWR pads solder jumpered as they should have been. Take a look at the photo here:
