I’m on a static network (/24). Tried using arp to force the address change, with no luck. Is there a default IP these devices roll back to (Lantronix xPortPro NIC).
Do I have to use software to change the IP’s, or is there a web server built in?
And I just realized your XPort Pro modules are being used in MirX so they have a different image than what I was referencing completely so I got rid of my old comments.
For the MirX Ethernet pairs you need to make sure the Beacon/Smart mode on the board is set to the Smart position as per document: https://ncd.io/mxnet-quick-start-guide/
