Hi, we are using a couple of boards PCA9547 in a serial connection. The first board without any jumper have the 118 address, but I can really understand how jumpers work. If I close the jumper 0, what address is it?
so if you set jumper 0 to high the address will change to 119 .
if you keep jumper 0 low and set jumper one high the address will be 120 and so on.
You can find the address info in the PCA9547 datasheet as well.
