I installed my sensor on the gearbox to measure the temperature and vibration.
However, I think the temperature does not make sense, so I use a thermal camera to verify, the temperature difference is too big with the sensor.
I want to ask, where the thermal sensor on the sensor?
Thank you!
it measures ambient temp not the surface temp.
also press reset on the sensor and let it go through self calibration.
