Can the NCD temp and humudity sensor sens data to google sheet ? I already have a monitoring interface running on this platform, can i use the data from the sensor on this platform ?
Hi Vince,
Its definitely possible, but you would need to set up the interface between the two. If you use Node-Red then I believe they have a node for integration that our node’s can feed into.
Actually here’s a hackster post on someone using one of our sensors with a google sheet: https://www.hackster.io/rjrajbir/node-red-to-google-sheet-7150ba
