Recently purchased 3 1-Channel Push Notification Contact Closure Input Over Serial boards. Checking operation with terminal program. Device sends 22 bytes on contact open, another 22 bytes when contact closes. Manual indicates this can be changed from send on open/close to send on open or close. Configuration screen doesn’t match mine. Can the send operation on my model be changed? How?
Yes 1 channel
This is what I see when I press and release button once
B4 08 01 00 00 00 00 00 00 00 02 08 00 4C 41 42 45 4C 01 01 00 29
B4 09 01 00 00 00 00 00 00 00 02 08 00 4C 41 42 45 4C 01 00 01 2A
I apologize, but it looks like the documentation is incorrect on this point. The operation cannot be changed. You will need to ignore Open or Closed in your software to only react on one input status.
