Hello - I recently purchased a 16-relay board - ZADSR161DPDTPROXR. When I send in a command I see the LED bar graph go active but no relays pick. After a little probing it looks like pin 9 on either of the TPIC6B595 registers might be floating or not driven properly. I probed with my DMM and when I set to measure volts and touch pin 9 (either '595 or pin 5 of the PIC) relative to GND the relays suddenly activate. I’m thinking it might be a defective output on the PIC because it does appear to be connected (and GND is connected, too). If there are any tips on how to repair this I’m all ears. I bought a bunch of these cards and this is the only one that exhibits this problem.
Keith
