Relay enclosure case
Does NCD sell or recommend specific cases to enclose (key fob remote) relay boards e.g.
https://store.ncd.io/product/key-fob-remote-controlled-switch-2-channel-general-purpose-long-range-wireless/
Hoping to find a case with no or minimum effort required to get access to power jack, antenna etc.
Vincent
Hi Vincent,
That board is profiled to be house in this generic enclosure:
This is an un-drilled enclosure so you will need to drill holes for antenna, power, and contact connections.
