I am using the 1-Channel 4-20mA Current Loop Transmitter I2C Mini Module (MCP4725) with a raspberry pi (with I2C Expansion Port) to power a valve using 4-20 mA. I use python smbus to write to the DAC, however, it seems like I need a power supply of 6 V in series with the output in order to receive correct measurements. Is this correct or have I misunderstood something?
