i m using reactor relay board and it is working fine , now i want to add some manual controls using new kfx module , how i can use this new module in reactor board.
i found in reactor manual some commands that i can use . i already configure reactor board and kfx module. i turn on relay 1 with timer 2 fort 3 seconds.
to activate timer 2 code is 64, 2, 1
when i pressed button in my remote kfx led on and also busy led in reactor is on for a moment but reactor relay does not activate relay 1.
it activates relay 1 but bi have to try many times .
i need press button one time then relay activates.
Plug the KFX back into your computer for configuration. Make sure Protocol is set to RAW and not NCD API as that will add additional bytes to the packet which Reactor does not understand. See this screen shot for what I am talking about:
i checked as you mentioned, but still is not working properly, i have to press many times button on key fob and some times reactor board relay activates relay as i want.
Try changing the setting Allow Multiple Commands per Button from 1 to 0. I think a bunch of 0s are being sent on the end of the command which may be confusing the Reactor controller.
Yes, R85PL is specifically designed for KFX. Reactor never really was and honestly I’ve never tried it. I don’t see why it wouldn’t work but obviously its not.
How long ago did you purchase these boards? If it’s within 60 days you can return that Reactor board in exchange for an R85PL.
