I have a new R45PL_KEYFOB board and something when I release button on the keyfob the relay stay ON ? Do you have any idea what I can do with this issues?
Thank you
Thank you
The commands that are sent on push down and release are configurable, but you’ll need a USB configuration adapter to make these changes: https://store.ncd.io/product/usb-configuration-adapter-for-ncd-communication-modules/
You can find more information on how to configure the commands on the guide at https://ncd.io/kfx-key-fob-communications-module-quick-start-guide/
Thank for your answer, but most of the time the relay work properly. This situation occur only aleatory. Do you know if any option exist for this kind of glitch?
Ah sorry i thought you wanted the relay to stay on when you released the button.
What load are you switching with the relays and is the relay controller running off of an isolated power supply that isn’t being shared with anything?
For now no load connected. Yes the controller is connected to an isolated supply.
I ran some tests and it appears that if you hit two buttons quickly then the relay will fail to turn off.
Is that what you are experiencing?
Yes exactly the same problem. What can I do with that?
I don’t think there’s a fix for this as its an issue with the underlying key fob technology.
