I have a R45PL_KEYFOB and I have a 8 button relay. I want to make buttons 1 and 2 to operate relays 1, and 2 (that came standard from the factory) but I want buttons 7 and 8 to operate relays 3 and 4. Is there a way to do this without getting into the programming software?
Hi Tony,
No, the KFX module must be reprogrammed using the Base Station software. This will require this programming adapter:
You can purchase the adapter and do this yourself or you can return the device to us for programming. This programming is covered in this guide:
